The evo header lands in the stock location with the same flanged connection yamaha uses. If your turbo uses the stock header the evo header will work too. So I'm told anyway
how much weight savings when install evo head pipe?
I've built a lot of Yamaha sleds, front mounts, rear mounts, mid mounts and NA sleds. The single best improvement I've felt/made on any Yamaha sled was to use a Rev tank on my Rx1. That one mod changed the handling of that sled dramatically. Kudos to the Doo engineers for that one, they had and still have balance figured out. I don't see the same level of thought/planning in the Viper, witness the header, at best its a factory mod sled. When Yamaha brought out the Nytro it was a clean sheet of paper all be it with it's issues but still, this new sled is a retrofit, it's just not the final answer and hopefully its not their best effort.
Again JMO
M5
Moving some of the weight rearwards could only help.
Maybe I'll get slaughtered here, likely but here goes.
That header design is the reason I have no interest in the Viper. I can't possibly see how a design that clearly evolved from:
"Hey how about we phone up Cat and just jam the Nytro motor into a Cat chassis and see how that goes".
"But what about the exhaust?"
"No problem we can just make it do a 180 and put all the weight up front, no one will even notice"
"We will just let the aftermarket guys solve all the problems with turbos"
By the time the exhaust does the 180 and gets to turbo it has easily encountered as much resistance and travelled as far as a Nytro straight thru system on a rear mount which incidentally balances the sled perfectly, I'm sorry if your supercharged Nytro was a front heavy POS but I told you so 5 years ago. When doing a forced air heating system in a home a single 90 degree bend creates as much resistance as a 10 foot run of straight pipe.
I really don't see the draw of this sled, sorry. I've been running Cat geometry skids in my Nytros since 2008, everyone said I was nuts now that the Yamacat is out everyone says how great they handle, well duh.
My MCX turbo Nytro is sub 600 and my Nypex is 610 RTR, the Viper isn't even an improvement in weight really and it has a crappy exhaust design.
JMO
Maybe the Viper will bring about world peace.LOL
M5
Ya Buddy!I noticed on mine when I push the flipper to the bar it seems all the weight moves to the rear quickly?
