I believe the heat soak problem is the tmap sensor. Which is the air intake temp as well as the baro. The sensor on these kits does not reach into the direct air flow path so it cant read temp changes quick enough. It ends up reading the temp of the black silicone hose instead of the instant intake air temp. Ive confirmed this by cutting the little hose shorter that the tmap is in. My intake temps went up and down quickly all the time ( reading cooler and hotter, relevent to being part throttle and full throttle as one would expect). It also started really easy and idled perfect after being shut down for a couple min. I did this back in 2014 trying to find a fix before the goat 6 tune came out. When the goat 6 tune came out i added the exact length back to the hose so everything would be as silber designed it. Shortneing the hose is on one of the things to try again when i get out next.
