Finished...I hope
Got it all put together and went for a ride today. About 30 miles of thumb killing to get it broke in right. Here's my steps/advice for anyone who might want it:
Steps
-got a syringe/suction thing from autozone for $14.99 and sucked all the coolant out of the crank case
-once all cleaned out, fill the crank case with VES gold oil. About 1.5 quarts. Read this in a article where a guy was installing a fix kit. The idea is that it displaces any risidual water and lubes the crank up.
-clean and air dry syringe with brake cleaner, then suck oil out of crank case. Rotate engine, wait a couple minutes then suck out he remaining oil.
-take cylinders inside and check ring gap. #1 was a thicker ring with a tighter (.3-.4 mm) end gap. #2 ring was thinner with a looser (.4-.5mm) end gap. Two of my rings had to be filed down. I used a flat file, then a finer triangle file to clean it up after i got them right. Didn't want any burrs scoring up my cylinders
-for security, I packed a bunch of blue shop towels around the connecting rods in the crank case, this way no circ clip would drop down in there during reassembly.
-using 2 stroke oil as a lubricant, I slid the rings on the pistons and inserted each inside circ clip. My pistons had arrows which i was directed to point towards the exhaust.
-put rollers in connecting rod (lube), piston over rod, slide wrist pin (lube), insert outside circ clip (eye protection, they have a tendency to fly out right when your face is up on them, don't ask how i know)
-now, the directions for my piston set said have circ clip openings at 12 or 6 o clock. I've read 3 and 9 also, but followed the directions on my kit, each piston had one at 12 and one at 6
-install base gasket, and PTO power valve (loctite). Have PTO piston slight higher than MAG. with a sharpie, i marked where my locating pins were on the top of the piston, this helped me know where the ring gap should be and made compressing the ring easier. Lube cylinder and piston, and work the piston into the cylinder paying close attention to where the pin is. It took a while, but I was trying to be extra careful.
-fuel rail. I went to my dealer and got new injector o rings as they did not come with my kit. $6=easy piece of mind
-once cylinders are on, I put four bolts in the cylinder to line the gasket up then tightened them by hand and rechecked that the base gasket lined up well. Inserted the rest then started torqueing, working from the middle out.
-install head gasket and head o rings. I used just a dab of assembly lube to hold them in place. I've heard these o rings are quite crucial to get right.
-install cover gasket and spark plug o rings. Loctite and torque head bolts.
-reinstall water pump with new gasket
-install thermostat (I tested mine in a kitchen pan with water heated to 140 to make sure it worked before installing it) with new gasket and the bridge in line with bolts
-reconnect lower coolant line and fill cylinder through thermostat. Re install housing (loctite)
-reinstall knock sensor (check torque specs, manual seemed pretty adament)
-reinstall temp sensor. I used plumbers tape on that fitting
-MAG side power valve (loctite)
-reconnect oil tank (picked up skidoo cap $15)
-reinstall overstructure, pipe and can (almost forgot little square rubber bumper on bottom of pipe)
-jack up right side (MAG) of sled and fill coolant through reservoir
-get a metal coat hanger and put it around the oil pump injector that works with your throttle.
-first start. Once running, I pulled up on the hanger to open the injector fully which bleeds the oil line coming from the tank. Did this for about 2 minutes.
-remove coolant cap, let sled get up to temp and have coolant ready to fill reservoir once the thermostat opens. I did this all while it was jacked up on its side. Supposed to help get rid of air trapped in the system
-I had a full tank of straight gas. First tank on new top end is supposed to be 50:1, so I added 28oz of VES. 11x128/50=28.16
-ran it today, 1/4 throttle burps up trail for 5 minutes, 1/2 throttle burps for 5 minutes, 3/4 burps for 5 minutes...then i just rode it like it meant to be. We have about 3' of bottomless powder so it was a pretty good work out. Power got better as the miles ticked away.
Advice
-clean shop. I'm not that clean and in turn i kicked over brake cleaners, oil tanks, coolant bottles and beer cans. It sucks.
-take off overstructure, oil tank, clutch guard, secondary and upper air box. It made things easier for me
-have a helper for the marrying of the cylinders to the crank case. Just don't let him rotate the primary without telling you. That hurts fingers
-I bought a 1/4 drive ratchet and socket set for $20. It's nice, I don't care how un-manly the auto parts store greasers think it is
-find the service manual. Torque specs and other random tips can be found here faster than posting on forums
One more ride tomorrow to decide how worthy my first top end, or any work on a snowmobile really panned out. So far, it seems good. 122 degrees on the trail for 7 miles straight tonight made me feel pretty good.
if anyone wants to correct me on anything i did, by all means do it! You guys got me beat by a mile on this stuff.
Thanks!
![IMG_0609.jpg IMG_0609.jpg](https://www.snowest.com/forum/data/attachments/222/222407-49886951938d05fe5f9a30f1b5323515.jpg?hash=SYhpUZONBf)
