2012 Silber turbo center section
A friend of mine put a garret 2860 on his pro to replace the silber unit.
Sent from my SGH-I337M using Tapatalk
The bolt pattern is exactly the same and it is a direct swap. I have the KPA ball bearing in stock as we'll if your interested.
Sent you a PM. let me know the part number of the turbo and price? Would like to try to get it going soon. Thanks.
In the end we just installed an NPT/hose barb fitting in the tank, connected a hose(fuel line), and left a wrap or so in the engine compartment with the end of the hose dumping into the belly pan.
Bottom line is that the reservoir for this turbo system required a venting system with no restriction whatsoever otherwise the turbo would leak oil around the seals immediately.
On the Skidoo XP oil tanks there is a in line check valve. If you put in your barb fitting, fuel line/hose, and check valve it works really well. I would have a lot more confidence in that, than a cap.
