Water to air areocharger so with that you have to keep in mind a water pump, a/f gauge, egt's and dobeck box all spliced in to wire at dc power plug and is also the same place I checked voltage. Now before jumping to any conclusions I have have to tell you i have disconnected each one starting with water pump then egt's then a/f checking voltage after each seeing only minimal change from 7.6 to maybe 9.2 now to add to confusion sometimes when first started cold and just the dobeck box connected it jumps to 12.4 roughly and after a few minutes slowly drops below 10 volts. Ahhh very frustrated
with the voltage problem on these sleds i want to wire in an on off switch to the head lights they are using at least 100watts of power.. now if i do this will i have to worry about anything?? oh i forgot i am having some idle issues with my turbo.. only aditional electrical other than stock is a/f guage and oil pump..thats it
I have the same problem on a 13. Swapped VRs yesterday with the gfs sled and no change. I think its idling to low and read about another one on here that the dealer fixed by turning up the idle a little. How do I turn the idle up?
