P
Pure Logic Tuning
I will answer a few questions on the tial set up. The upgrade is $1800.00 complete. This system has faster spool time with greater mid to top end power. The kit was tested all year last year. The complete turbo kit is $6500.00 the kit comes complete with clutching, gauges, handlebar mount for gauges, boost gauge, fuel pressure gauge, 02 gauge and side panels. This kit has some very special features, the cylinder that allows the wastegate to relieve boost pressure is ported 360 degrees around the cylinder to prevent disturbance in the flow of a 2-strokes tuner pipe. This was very important when the unit was tested as we all know you can't just put a one inch hole in a pipe and not drastically effect the performance of the pipe. This cylinder also allows the tuner pipe to use a standard gasket so it is not rigid mounted and the consumer can replace when necessary and not have to use woven flex exhaust material. If you have questions you can contact OVS at 801-940-7777 we will answer any question you have. Then Kevin can get you the kits that you need.
