Once I have the tool, Multimeter, and TPS... Can someone guide me on How To remove the throttle body and set the new tps ? I can go live on Skype. Somebody that has been there and done that please ? Thankx !
Well the dead spot occurs at the same spot the Voltmeter drops... What is the Voltage spec for a CFI 2009 RMK 700 at WOT on the TPS ?
If your using an auto ranging meter, then change the setting from 0-4 volts to 0-40 volts, then it wont drop out.
From reading your posts, I dont think this is something you should take on your self. The TPS setting is the single most important adjustment on these sleds.
If you want more details on it, go into the Axys forum abd at the top of the page there is a tech link stick, there is a post about TPS adjustment. This will give you an idea on what your getting into. I will say replacing the sensor is much easier on your sled, but the adjustment part of it is much the same. Eric
