A
By switching coils you mean the spark plugs wires right at the spark plug? Have you tried running it with the plug wires reversed but both hooked up? I am thinking it will still run on the stator side with the plug wire that normally goes on the pto side. Just trying here to isolate this to a cylinder/fuel problem vs an electrical problem. Sorry if I am not understanding what you mean by swapping coils.I ran the snomachine with clutch side spark plug off and it started, then when I tried to start it with the stator side off and the clutch side on and it wouldn’t run, and then I tried switching the coils to run the clutch side and it never ran
I have tried switching the coils and not just the wires but the whole coil itself where the connectors are and still the pto side would just fire on and off with backfires, I’m thinking I need to adjust the tps setting. When I went to pick up the sled I had to have the throttle at half throttle to have it started and the idle was low, so I adjusted the throttle cable that’s by the handle bars, so maybe the tps must be off in my opinion after reading out it somewhere on this website. I’m still new to this cfi sled and learning about it slowly as I’m trying to figure out the problemsBy switching coils you mean the spark plugs wires right at the spark plug? Have you tried running it with the plug wires reversed but both hooked up? I am thinking it will still run on the stator side with the plug wire that normally goes on the pto side. Just trying here to isolate this to a cylinder/fuel problem vs an electrical problem. Sorry if I am not understanding what you mean by swapping coils.
You dont need the tps tool to set your tps you can set the tps by plugging your power commander into a computer as long as you have the power commander program or you can set it with a good multimeter.Thanks again retiredpop I’ll adjust the throttle on the throttle body after I get one of those tps tools
