Dog gone these things are hard to find with all the options I want for the right price.
Haha you got efi live tuning bud. It is the most advanced tuning software that there is. It makes edge and bully dog tuning look like it was done by a 5 year old. Tell your tuner that you want a dsp-5. A dsp-5 is a knob with 5 diferent volts that is wired to your ecm. The good lads at gm left the availibilty to have 5 diferent tunes stored on the stock ecu. So! I had alight tow tune, a heavy tow tune, an economy tune, a hot tune that smoked like a mofo. And a max effort tune for racing. You can have your foot in it and change the tunes by turning the knob and feel the power diference. Its ****ing awsome!
Try and find what tuner it had on it that will kind of give you an idea how it was treated, if that tuner runs alot of railpressure keep in mind that injectors will be in your future, as with any common rail buy some sort of filtration setup like a fass which is what i prefer as it seperates any fuel, takes out most of the air "verybad" for injectors and it also filters the fuel better due to there high pressure at which the common rail runs at any dirt or air kills them exstremely fast.
I would personally go with an 08 up get there newer bodystyle and interior some deletes and efi live transgo kit and ats copilot to get rid of the pos adaptive learning in the trans and enjoy
I finally found one. I flew down to Atlanta GA to pick it up saturday. Thank you to my Frequent flyer mile points flight was free. 2006 2500HD Crew LT2 with a LBZ Duramax.
Truck looks good! If you care there are some ways to figure out if the truck has been modded.
Gauges on the pillar or holes in the pillar are good indicator.
Exhaust systems and cold air intakes.
Exhaust temp probes in the exhaust manifolds or plugs.
Truck looks pretty unmolested... Any of the above done to it?
I have no reason to believe there has been a tuner on the truck. It is a one owner truck according to the carfax. Doesn't mean it wasn't tuned but I can look for the aboved mentioned holes.
Congrats! I bought a 2007 LBZ two years ago and have loved it!
I have the cognito 2" level kit on mine, 4" straight exhaust, Edge tuner, EGR blocker. My next mod will be a lift pump, so i can get rid of the damn fuel pressure code that goes off everytime i put my foot into the pedal! im up to 150K on mine and runs like a top.
Your first mods:
4" Exhaust (turbo back)
Small Tuner
Fuel mileage will increase dramatically with just those two mods.
I get 16 mpg with two sleds on the deck at 80 mph. i always see 19-20 empty at 80 mph...
4" exhaust to delete the cat, PPE tuner or a Diablo sport are pretty much your best hand held tuners & those two can get good economy as well. None will match EFI LIVE but for a first tune PPE or Diablo will work well. I'm not a fan of the "on the fly switchable tuners" there hard on the transmission, mainly because of the adaptive learn feature... I would block the EGR and reroute the PCV. EGR plugs up the intake tract going into the heads by dumping hot exhaust soot into your heads, add the PCV dumping there you get a nice black mess that restricts air flow. A fass or air dog is not really needed, you can accomplish the same thing for less money and have superior filtration to either one. A lift pump is only needed for above 450hp to the rear wheels or if you are getting a low rail pressure during power regemin codes, that said supplying the CP3 pump with positive fuel deffinately won't hurt. A trango shift kit is good cheap insurance it takes your stock line pressure and basicly doubles it for better clutch holding power, it is cheap at about 80 bucks and can be done by the average guy as long as you pay attention.
I have my tuner set to the 85 hp level. Soon as i get the tranny built i will run it on the 100+ hp tunes. My truck always throws the Fuel Rail pressure Code, especially when towing, which as i understand is the trucks way of saying it needs more fuel than it can supply off the stock pump. Hence why i wanted to get the lift pump. Am i wrong on this?
At 85hp you shouldn't get a low rail code. What is the code, p01093? What year is your truck, mileage, & mods done? A lift pump may help but I think it would be masking some other fuel problem... I just went through all this on my truck so it is pretty fresh in my mind.
If your looking for Duramax transmission & performance stuff in Utah I recommend Trent Nell, he built a 9 sec d-max.http://extremeprejudiceracing.com/Default.aspx
Yes thats the code. I have edge evo set to 85. 4" exhaust, EGR blocked.
2007 LBZ motor with 160K miles (i drive a lot).
