C
cat10
New member
Hey everyone. I need some help. I recently acquired an m7. Was told it needed an oil injection pump. Got it cheap so if it’s junk I’m not out much. It has a can on it. It will start right up but that’s all. When I throttle it it dies. 120 lbs compression on both cylinders, pumping fuel to the rail for injectors, has good spark. Any ideas? I don’t understand how the oil injection pump can cause this? It does seem to be pumping a lot of oil through the engine. I’ve heard when the pump goes bad it sticks wide open. Any help would be appreciated
