Rapid Bike 2 bar to 3 Bar
Rapid bike 3 can run up to 100% duty cycle same as Dobeck which is Purelogic, MPI, and many others are all the same with different programing.
RB3 is like having a stand alone system with real mapping.
A lot of guys are knocking the RB3 that do not have any knowledge about EFI.
If LOAD setup and Voltage is not setup to run in the map properly then the whole system is out of whack.
Add timing in the bottom end for quick throttle response and retard/pull timing with boost for more HP without detonation.
A proper map with also give great fuel mileage.
Even with Tuning Bike you have to know how to use it to make proper maps.
Anyone that has seen what we do with a sled using RB3 knows how much better we make it run.
I have always been a tuner since the late 70's on Motorcycles, snowmobiles etc.
We get a lot of guys running RB3 with a 2 bar map sensor and they need a 3 bar sensor to run over 15 psi boost.
You cannot run more then 15 lbs boost with a 2 bar Map sensor!!
Bring us your Boosted sled with whatever kit you have and we will make it smoke your buddies same setup hands down.
www.powderlites.com
