These tracks should be looked at like a tire on a dragster... an expendable, purpose built tool to get some extreme work done outside of what a consumer offering can provide... In the conditions that we are running these tracks in, the Horsepower and speed that we are getting out of these sleds... don't compare them to the the durablilty track on your 2000 Mountain Max/Summit/SKS/Powder Special. With the loads todays sleds are putting on these tracks..they are actually more durable than Your ole 1.5" paddle.
If you cram 200+ HP into a track and generate 90mph track speeds in the fluff and hit a hard ice chunk, stump or rock... you will loose paddles... If you don't like this, get a shorter lug track that is not so stiff... YES your performance will drop, but your track will last longer and be more durable.
If you must have the higher performance that the tall lug tracks will give you... accept the shorter life of the track... you can't have both, IMO.
Proper tension (not too loose) on these tall lug tracks will give your sled better performance and longer track life as well.
There are some defective tracks just like there are defective computers, tires, snap-on tools ... you name it... But, Camoplast builds a very high quality product.
If you have a turbo... and are running the 3" lug, well, you should expect to putt along on the trail at 30mph max with scratchers down and expect that these stiff & Tall lugs with all the leverage they can put on the belting will shed some paddles when you are climbing the gnarly chute... or boondocking and snag a rock or ice chunk. ... you should expect this.... and to a certain degree, you should expect this with the 2.5" Extreme if you abuse it with high speeds and/or run over stuff at on a 250-hp+ pull with 80mph track speeds...
The damage to a track that sheds a paddle probably happened earlier in the day/week/month/season.... From that high speed run back to the cabin/trailer or a that 300 ft long sheet of ice we barely make it up fully pinned WFO. The heat that builds up INSIDE the rubber at the root of the paddle is what starts the process of delamination...this heat occurs because the paddle is forced to bend too much at the root ...from the heat of high speeds... in marginal snow... back and forth, like breaking a paper clip by wiggling it back and forth (different physics, I know... but the visual is what I'm going for here)
In order to run a taller track you not only have to maintain the lug tip clearance, but you have to increase it (on stock tunnel/skid/drive). Simply put, a taller lug will move more snow. The more snow you have to move out the front of any given tunnel-opening, the more parasitic loss you will have ( “pumping-loss”).
To illustrate this, look at any action pic, in the pow, where someone is on a "wheelie" for whatever reason... you will see gobs of snow spraying out the front of the tunnel. The tighter the opening is, the more power it takes to push the snow past the restriction (the opening at the front of the tunnel at the bulkhead)...
Getting a track to fit, and having it run well are not necessarily the same thing. If it comes close to rubbing, IMO (as well as Mark Holz, Mike Vanamburg and others) it has no place on a properly set up deep-snow sled.
People riding in light champagne powder will have a whole lot easier time getting thru the snow with little clearance than wet heavy pow... like we get on the west coast.
