2.5 camo extreme 9175
Superduty348
Is anyone running the the 9175 162 c/e 3" pitch on there pro?The new design camo ex? How do you like it on the pro?
I've run the 9174 155 (same track, shorter length) on an '11 Pro ... with 7 tooth drivers (chaincase mod required)
It was better in the fluff than the original camo extreme... I did not notice any loss of performance in our heavy costal snow compared to the same....
Much better, IMO than the standard 5.1 track with less weight... I have a peaks sitting here to try out... but ZERO snow here and I'm not road tripping till feb.
so u have go to the smaller drivers to run the 2.5" lug? it wont fit?
It will "fit" without it. However, it will not WORK near as good as it should. I did this on an edge sled. I went with smaller drivers that allowed the 2.5 extreme to "fit" in there, however when you get in the right snow conditions mainly deep dry powder it would plug up at the front of the tunnel and saw a drastic lose of track speed. I'll never get cheap or lazy when putting a big track in again.
