Ideally, someone would have a sensor/sniffer setup, try different maps while snowbiking at elevation... and have a portable dyno up on the mountain. Ha. But short of that, most tuning with onboard mapping is seat of the pants and educated guess.
All last year I had two maps loaded on my 2020.
For offtrail riding, I had FI at -3 across the board and ignition at +3 across the board which had good snap, didn't use excessive fuel, and ran good temps (though temps are more a result of other setup).
For those tight, slow mogul sections where trees are so dense you have to stay on the trail and slowly hump through the deep whoops on a narrow trail, I didn't want to reduce fuel here and so I didn't minus out fuel and instead kept it at zeros, though one could experiment with adding a little more fuel if you were really running hot in this situation. On fuel, I did set the lowest rpm and lowest throttle setting to -3 with the thought being it would push less fuel during a cold engine start up and warmup idle and not overfuel (as much).
My trail map also retards the ignition (reduces the power) in some areas to reduce whiskey throttle incidents. I left high rpm and high throttle opening ignition settings advanced in case I needed the power up there, so it will behave like my deep snow map at high rpm and high throttle openings. But all low throttle-opening timing is retarded all the way through the rpm band and is also retarded in the first two rpm bands all the way up through 100% throttle opening, meaning, if a mogul kicked me back and throttle wraps wide open, the retarded timing tames the power to make it way more controllable and recoverable. It has saved me a few times on the way out when you are super tired and a bit more prone to getting off balance.
These settings work for me and my riding conditions.
The difference, between the two maps, is obvious and the 2020 YZ has a handlebar mounted, illuminated button to toggle between two loaded maps. If I forget it on one setting, it's obvious by feel when I'm on a different map than I thought. To me, being able to quickly switch back and forth between two maps at the push of the button is the real value of this setup, even more so that tuning a little more power and little less fuel.
