18 thermostat in a 16
ullose272
Has anyone figured out what is needed to put the thermostat out of the 18 in a 16 engine? Thermostat housing and head cover? Or head as well?
Sent from my SM-G930V using Tapatalk
You need a head as well.the thermostat is deeper as well. I just put a Bikeman 18 upgrade head on my 17 in January. More cost effective than oem. Run high 90's most of the time.
I was looking at that, how do you like the bikeman head?
I also did the y-pipe, pipe, powderlight can and bullydog. It pulls way better mid to top end. I am pulling 66gr weights at 5-7500ft. 8350rpm spot on for the bikeman stage 2. I did the 0-6000ft head instead of the above 6000 head. Didn’t want any issues as i ride a lot at 6000. I like it and would do it again as it did exactly what i was looking for. My son rides my 2015 pro and we compare temps all the time and it runs 20 -25 degrees hotter on average.
Did the same setup as tb did. I find my sled runs about 10* warmer than it did minus the head / bulldog.
Had the pipe/can previously, with a PCV from dyno Jim and his map in it..
Pulls like crazy tho with the BMP setup. 68.5g at 4200' and I'm banging out 8400-8550...
2016 Slp stage 3 with 18 head skull
Running 94 degrees in the powder
Pulling 43 mph track speed at 9000 ft.
8350 to 8400 consistent rpm's with tied secondary and magnum force weights
Indy specialties 18 tstat cylinder head
Call up Indy specialties. They released a billet head that uses the 18 t-stat. I run there turbo clutching and there hg7 cylinder finish. Quality, Knowledge and service is top notch
You are using a slp 18 head?
