I took my sled into Carl's for Cold/Warm idle issues. The Tech's said there is a "TSB" for it which is a new ECU Flash. [Team Tip S-16-02-03]
Post Flash the issue I brought it in for is gone, (Yippee!) But I noticed an uptick in Oil Usage after. Not Break-in levels, but noticeably higher after ~100 miles on the new update.
I talked to the Tech's again today about it, curious if something else was done or if it was accidentally put back into a break-in mode somehow.
They said the ECU updated applied brings my 16' up-to 17' ECU level's, and they are getting reports of the 17's burning quite a bit more oil than the 16's are.
I know two 16's that burned down this season (Ring Failures). Are any of the 17's owners here seeing higher oil usage than the 16's? This sure peaks my interest....
