16" wide track under a ZX?
It'll fit, you need to grind down the chaincase bolts a little, look under there and you'll see which ones, grind the ribs on the rear hangers and maybe the odd rivet or two. I also used washers on rear suspension cross shafts to spread tunnel and give a little more clearance. Good luck
Dave
I did my 03 and did not have to grind anything. I was limited to 2" paddles. Best upgrade you can do for this chassis. I highly recommend simmons flex skis too. Makes the sled feel 100 pounds lighter.
I will have to agree go 16
I did VE dropdown brakets with it. Best mod for the money. I did SLP CAN SLP Pistons, v force reeds and the only thing I felt was worth the money was the track. 151 off an 04 rev works awsome. I can just point and boondock even better now
Did the mod to both an 02 and 03 summit, you will be very happy with the results. You do need to watch the clearances inside the tunnel since it will be a tight fit. I trimmed the drive shaft bolts, trimmed the drop down brackets and put one washer on each side to spread the brackets out a little for more spacing. The track will need to run very close to center. Works great.
I did it to my 03...awesome and cheap mod that gives you the bang for your buck you've been looking for. It's really easy I just cut a peice of cardboard that was 16" wide and ran it through the tunnel seeing where it would hit. A grinder and some spray paint is about all you'll need to make it work. Let us know how it works.
