I am have been pulling my hair out over a gremlin in my girlfriends sled, 16 axys 800 with just under 3,000 miles.
The sled will run flawlessly 98% of the time… However it will randomly cut out, it seems to happen under any amount of engine load/rpm/throttle position. When it decides to cut out it will flash the check engine light the entire time, and will continue to cut what seems to be ignition until the motor completely dies.
Once the motor dies you can restart the sled on the first pull and it will run like nothing ever happened. Sometimes it will make it 2 mins before it cuts out again and sometimes it will make it 30 minutes.
It is extremely random and frustrating, so far I have eliminated the tether, kill switch, and throttle safety (installed the bypass).
I have replaced the voltage regulator, Also have checked OHM readings on the stator and coils.
Contemplating paying for the dealer to reset the TPS, any input would be greatly appreciated.
Thanks in advance
Thanks in advance
