The drivers came with instructions from Avid, the outer edge of the pto side/non center tooth driver goes on 12.5" from the very end of the mag side of the shaft, and the inner edge of the center toothed driver goes 9.5" in from the end of the shaft. Its kind of tough to measure really accurated since the spline end of the shaft sits about and inch lower than the shaft itself. I just used a tape measure the best I could, made markings and pressed them on. Once on there is an inside distance that is measured that is supposed to be 4 1/8" +/-1/16"
I have a feeling mine aren't exact, after installing I noticed that my center tooth is not exactly centered, probably off about 1/16"-1/8", I wouldn't think it is enough to cause any issues.
I can get a measurement this weekend. And after I installed everything I could not get enough adjustment to get the track tight, it may have been tight enough, but after stretching there would not have been enough adjustment. Carls contacted me and they had some people out testing the track and it was transferring pretty bad and they had a lot of ski lift.. sooo Carls recommends moving the front arm mount on the rear skid back to the hole located directly behind the factory one. You have to drill this hole out with a 25/64 bit from inside the tunnel, there is a pilot hole on the steel plate inside, this is supposed to help with the transfer and gives you more track adjustment. There is also a little bit of grinding/cutting that needs to be done on the stopper on the rear arm, which is supposed to allow for full travel. I will get pics of all of this this weekend. My track is plenty tight now, and will still have adjustment after it loosens up or stretches out. I will finally get it on the snow next FridayJust out of curiosity, what are the dimensions of the hole Carl's had punched in the X3?
PV
IMO you cant puch a track accurate enough!!
Carls does not have track punched out they had a design change done to the mold so it can be done accurate and repeatable.
I sure wouldnt want to try and set the holes within a factory molded tolerance. nearly impossible.
What will happen if it doesn't "run true"? I noticed my track ran left and right a lot when I had it on the track stand, not sure if that's normal or not?A two foot square works well. I install the shaft in the sled without the track to make sure all is centered. Adjust if necessary, then install the track. This will insure the track will run true to the chassis. Not much room for misalignment on the PRO. With it true to the chassis there will be less rolling resistance.
