155” coolers?
MARV1
8,982
1,594
Kotlik, AK
Is it possible to just change the stock coolers on the tunnel instead of the whole $1500 assembly? Got a leak, no welder nearby.
Snowman10
33
15
8
I recently added the 3’ cooler from MTNTECH performance.com and it has made a great improvement to the cooling of my sled with a cut tunnel. For $275 plus shipping it was a great deal and it dropped the temperature by 40 to 50 degrees.
GoHiSK1
154
45
Melfort Saskatchewan
I have used JB weld to repair a cooler leak that I nicked with an angle grinder when I did a drop and roll on my 2012 RMK a few years ago .
Still holding coolant today .
MARV1
8,982
1,594
Kotlik, AK
One of my nephews told me to look into this and it’s needed as these 850’s can heat up quick
MARV1
8,982
1,594
Kotlik, AK
I did this and added a plate between layers to keep from flexing I’ll see how long it holds up
E
Aug 29, 2016
100
67
Buena Vista, CO
You can run a 3’ mtntek cooler as the only cooler and just chop your tunnel and leaking factory cooler. I did it on a 17 and it wasn’t any harder to keep cool than stock- maybe even slightly better. And the 18+ sleds run a lower thermostat so you should be good.
