13 Pro with SLP Pipe & PAR 13.6 head
jakey-boy
What map are you guys running and are you having to run any race gas to avoid det? Tried up to 70 grams of weight on the MDS. RPM seems to be under control but keep having det issues. Thanks for any feedback.
Riding 7500-11k feet with only non ethanol fuel. Will run okay on ethanol setting with non ethanol fuel but turn it over to non ethanol setting and it dets somewhere in the midrange. No airbox mods or reeds.
The 13's are real lean in the mid after a pipe and some compression. They need a lot of mid fuel added. Email me your map and I'll work it over for you and send it back later today.
Chad@a2dsledworks.com
Jakey boy do you have a hex bolt in each hole on the Mds weights ?
Not to hijack your thread but
IQRIDR I have a similar set up same head different pipe on the way would you have a map that I could use as a starting point.
Thanks
I have hex bolt & two washers on the tip. Little too much weight one washer would be better was trying determine if the det code was actually DET or over rev so I loaded up the weight. With that setup it will pull right around 78 on the ethanol setting and 7950 on non ethanol but will throw a det code every once in a while.
OK . Map for me also please.
Thanks in advance IQRIDR for a 2013 PCV map with pipe and head .
pjogmerracing@yourlink.ca
Have you a map for similar setup on a 2011 pro ?
Am using Bikeman single and stock head . Have had slight detonation issues with PCV map with SLP map for their single pipe.
Thanks for the Map IQ. I rode with it for the first time yesterday and the det issues were gone. Now I can start adjusting my clutching to make the sled run the way it should instead of detuning it to keep from throwing a det code. Will keep updating as I get more miles.
Please send a map to candd1@sasktel.net
Running a 12 pro rmk going to do mods this year.
I will have
MTN TK fix kit installed
slp pipe/can combo
PCV
PAR head 13.1
currently running rooster weights 73.5g for my elevation of 1900ft
This is my mountain sled and I use it there 95% at 6-9ft
I do however like to use it back home as well.
have a 11swb assault that is my main sled for here.
thanks in advance
