13 pro a arms on a 11 pro will they fit..
M
magician
New member
Bent both lower a arms on my 11 pro. Would like to go to a 36 in. set up on my 13 pro. If I could put the stock 13's on the 11 then I could get a set of 36's for the 13. Is there a problem with the shock length.. May just buy 2 SPI's for the 11.
The '13 uses shorter shocks and an 8mm lower shock bolt instead of the normal 10mm lower shock bolt. They will fit and work. You just need to change shocks the shocks also.
Depending on who's 36" arms you go with will determine whether you can use the '11 shocks or need shorter shocks. IIRC Alt impact may have a 36" wide that works with the long shocks. Call Dan and verify that first would be the smart course to take before committing to anything.
Did you end up putting the stock 13 lower control arms on your 2011? Did they fit no problem? I'm in the same boat ...bent my lowers and have a line on a pair off a 13. Do they fit with 2012 uppers?
