12v power supply
Under the hood, comes off the harness section thats with the gauge/headlight. Cant miss it. Its a SAE connector. Wired my GPS to it.
Yes.. Actually there is a couple places to Pull Juice from..
Yes ... as Stated above.. Next to the headlight plug in.. there is a Two Wire SAE Connector.. that you can Pull Juice from, Only thing that SUCKS about that is you have to disconnect it every time the hood comes off!!
#2 option...
Plug White by the Primary It Will be a 3 wire plug with only two wires... label DC PWR this is also where you can pull juice from!!
2#.. You don't have to disconnect from when taking off hood!!!!
Brown is Ground!!!
