Took my 12 Pro and had it pre seasoned. I was told that likely the plugs would need replaced soon. The sled has 775 miles and has in it, it's second set of plugs.
Took it to the mountains yesterday and rode for 2-3 hours without any problems. toward the end I began hearing a barely noticeable sound in the low RPM's. On my way back to the truck the machine started cutting and bogging and after several seconds it coughed, farted then just quit. Whipped out my new set of plugs and put them in. Started right up and off I went thinking problem solved. 2-3 miles later same thing. Coughed bogged and quit. Now knowing it wasn't a plug issue, I began to wonder what I had recently changed that might be causing the problem. I just installed a tether 10 days ago with this being the first ride with it. I unplugged the tether and gave it a pull. Started right up. Took off down the trail and it ran like a scalded cat, never giving me another moments trouble all the way to the truck.
The tether I installed was the OEM Polaris tether. Plugged it right into the available plug inside the velcro'd pouch containing wires.
Will this tether cause this type of problems. What can I do to alleviate this problem? I did remove the tether key/rubber several times during the day but did not notice and obvious amounts of snow or ice in the cup.
BTW, the machine did not show any lights, codes nor did it message me any notes of distress.
Kinda like having a tether so really don't want to leave it disconnected.
