B
briand
Have a 12 pro like the title says with a bogging issue since the kit was installed.
Just wondering if anyone has any advise as what is causing this bog.
Things I have tried so far.
1. I have checked the exhaust valves and cleaned them and did not cure it
2. look over the reeds and they are fine.
3. changed fuel nos. leaner and richer still no help.
4. plugged the exhaust valve hose after the solenoid and still no change
5. changed out plugs and even tried different gaps of .018 .020 .022 .024. nothing helped.
6. checked exhaust system, pipe for leaks and cracks none.
7. different levels of octane. and there is some help here but does not fix it.
8. lower boost levels. this seems to have the biggest change in the bog then anything. if you run lower boost level, say about 4 -6 # the bog pretty much disappears. Once you start raising it over 7# it gets progressively worse. If you ease into the throttle its gone but if you stab it, the bog is there over half the time. At 8 - 10 # of boost you can still ease into the throttle but you will start to get a bog here also and stabbing the throttle its there all the time.
9. Checked all turbo routing and hose connections all good here.
10 fuel filter was changed and pump pressure is good.
At a loss here, any advice on what to check or remedy this bog?
I have posted some of the bog issues in the Silber bullydog thread to as there are other boondocker turbos having issues too so i thought i would start a new thread about boondocker turbo bogs.
