My chaincase went kaboom today at 1180 miles , and update done 90-100 miles ago
When they did your update did the chain and gears looked fine or did they replace anything that was wore or broke?
where are you guys getting the micro belmont chains? I ordered one of the "heavy duty" chains for my 1100 turbo from bikeman performance and it was a micro belmont but its only 13 wide and the stock is 15 so thats not going to work I don't think. thanks for any info
I had a vibration like a driver ratchet. Turns out I had several random broken chain links a broken tooth that also punched a hole into oil tank! awesom right. In the end it was still rideable, just under heavy load would vibrate End total is 2 chains 4 gears outer chain Case housing and oil tank And tensioner. Under warranty thank god
