Buddy had the same issue last year. His was the temp sensor in the pipe. When it got good and hot on a pull it would cut out. We were way back in and a tow was not a pleasant thought so he babied it the rest of the day.
Mine did that, and it was hitting the rev limiter. The tach is a little slow to read, and it never showed much over 8250, but I switched weights and never had the problem again.
Common from 08 til present polaris sleds.
We usually carry a (well padded) spare sensor in the group.
Are the sensors that interchangeable that one from a particular year could be used for a spare? What year donor would you recommend?
My 11 started cutting out at all rpm.. Will it throw a code on this. Mine has no codes.
