Y
yzviper366
What are the other issues with the cylinder design?
I have measured at least 100 cylinders of the Polaris 800 and have not seen 1 where the cylinder was out of spec in any way..
The problem is not the cylinder, however, there are "other" issues with this cylinder design..
The problem is the piston design and is easily fixed with a "correct" piston.
As for a long rod and choked off air flow in the transfer ducts... Please get back with us on that after you "compare".. I think you will be very surprised at the top end "performance".
Care to elaborate on the last part there, not sure what you mean? I have been thinking that the longer stroke could not hurt anything and decrease the side load on the piston/cylinder skirts. Chose the LR since alot of people have reported good results and I wanted a fresh good running engine for next season.
I am running components from alot of vendors, so I have no bias against any particular one....just want to build a good runner and maybe learn a thing or two in the process!![]()
Also, history has shown that not all mono blocks are not created equal. Expansion and contraction from heat is greater/less depending on the area and the amount of material in that area. Don't know this for sure, but I would be willing to bet there are some goofy expansion and contraction issues going on. Then couple that with inconsistent cooling system.
.02
Thanks for the elaborate response Kelsey!
I am also VERY interested in keeping this thread clean and factual, people have different opinions and that is how things should be. I just want to learn and think out loud
I know that one of the mods available might affect the air flow, but this is related to a cylinder mod right? I can not se how changing to longer rods could alter air flow, the engine should "pump" the same amount of air at the same bore at the same RPM? more crankcase volume due to the shim...does that have an effect?
I was told by one offering a LR conversion that the altering of the angles due to the longer rods would lead to more efficient transfer of force to the crankshaft which in turn lead to better torque. Is there any truth here in your opinion?
Also, do you think adding a big bore top end to the LR bottom end would work? Or would mapping be an issue?
2) With a longer rod, you change the "dwell" time that the piston incurs at TDC and BDC.. this greatly effects the combustion event, and its timing.. sometimes for the better and other time for worse.. It also effect air-flow and many other parameters (like is true with any 2 stroke engine). So, when this happens (for the worse), power is reduced.
Just curious on how a longer rod changes the dwell time since your piston speed is based off crank radius (stroke) and engine speed? Is it longer or shorter? You're still at TDC and BDC for one CAD with the same stroke, so how does a longer rod effect anything other than balance and side loading? I have always heard that dwell time (combustion characteristics) is changed with stroke. I agree that poos rod ratio is normal.
I agree that in a 2-stroke the air flow would be effected since there is likely a larger crank case volume and the transfer port will be longer, but IMO that is effected by the 'spacer' required and not the longer rod.. just my .02
So in the context of the disadvantages of a longer rod; is there any differance in the slowing of dwell between a long rod kit and a "fix kit" with taller pistons and a spacer, or is it one in the same because the distance from the crank to the combustion chamber are the same?
Also how does it change it if the rods or new fix kit pistons are lighter than the stock parts that are being replaced?
I guess that's more or less what I'm asking.
Forgive the rough measurements as they are made up for the explination as I don't know the true ones;
But let's say you put rod in that is 1/4" longer than stock rod + piston length (X) and a spacer to match it. so now your distance from the crank to the top of your piston is X+.25".
If you put a fix kit in with pistons that are 1/4" taller than stock rod + piston length (X) and a spacer to match. Your distance from crank to the top of your piston is still X+.25"
In either situation you have added the same distance, does the piston still accelerate slower than stock with the fix kit as with the long rod?
I had asked indy dan about fitting kelseys pistons with his long rod setup, he did not reply to that email so i assume it was a no.
So could we counter act the negative effects of a longer rod with a lighter rod or lighter piston?
And has anyone heard of experimenting with combining a long rod with a fix kit or your drop in kit?
