I
INKEDRIDER
ACCOUNT CLOSED
so i figured out what the problem was took all winter but turns out my slp aftermarket domes are crap believe it or not the half moon shaped cut outs for the the bolts are way to big also not all the same size so heads up out there to anyone with slp domes very poor machining also they measure squish on a lathe witch is not the proper way, my o ring was getting cut by the dome and only 1/4 to 1/2 of the sealing surface was being used so i had the them filled and re drilled new holes the correct size and the problem went away
