10 M8 will only idle
03Firecatguy
Was riding sled and ran great. Mid day it suddenly bogged down and when it came to a stop it would only idle. Once you hit around 3,000 rpm it cuts out. Swapped ECM with another sled, didn't help. Checked all wires by coils and they are good. Throttle cable seems fine. Ideas?
The lever needs to be tight to the stop at the cable so the pin is pulled to the outside of the handlebar. When you push on lever you should hear a click when the pin hits the safety switch. If that doesn't fix it then you need to open the throttle block on the handle bar and disconnect it to test. I would not run it that way without a tether it would not be safe. Hope this helps.
