R
RideGuy
Anybody use Graphite to Lube the Button's in hopes to lower clutch temp's?
Well this is my first sled with a TRA button style clutch opposed to a roller P85. The sled is a 2009 Summit 163 no graphics. Out of the box I scrubbed the belt and clutch's with scotchbrite and soapy water. Depending on snow RPM's have been 7900-8100 on the Analog/Needle guage. Clicker 3 at 7000ft on Cheveron 94/BRP oil. BRP stinger and everything else stock.
Temperature's are going up and I've been feeling belts on sleds with/without vent kit's. Temp's even with vent kit's are impressive to say the least.... The belt guard is tight and I see why everybody are drilling them. Vent's O'plenty are necessary...... I think up near the steering column/exhaust console side would help vent the upper chamber and get things flowing from the bottom to the top..... The air box makes it impossible on the intake side... unless a guy went to an aftermarket intake but I've yet to be sold on one....
I've noticed the Secondary seems hotter than I'd expect them to be which makes think there is alot of slipage.... Does everybody adjust their deflection with the strings dead even with the top's of the sheaves as per manual or is it recomended to run the belt higher trying to minimize slippage/heat in the secondary....... Not to mention it can't vent off under that clutch cover....
I haven't toasted a belt yet and it appears to wear fine but with spring conditions I'm concerned about wear.......
I'm wondering if a longer stiffer secondary spring might help lower secondary temps.... When I did my project P85-Diamond Drive I was in search of belt life and low temps..... I ended up using the longer orange M1000 spring in my set up and I found what I couldn't find using stiffer short/stock size of springs.....
Anyway's sorry for the book... Just thinking out loud here...... I know it's been beaten to death... But my original question was in regards to the friction generated when the Button's slide.... Is there a Dry lube that may reduce friction heat?? I'm not even sure what a button is made of.... I haven't had a TRA apart yet....
