'09 Rmk 700 speedo not working
I have an '09 RMK and the speedo quit working and it is not counting miles. I am assuming it is an electrical issue since the bearing seems to be ok on the driveshaft. Wondering if anyone else has had this issue, could give me a few pointers before I start throwing money at it.
Is the whole gauge not working or is it just the speedo not working, i have a simular problem my gauge doesn't read at all it's just a dark screen, but the other things like reverse and high temp, and brake, lights still work. i've noticed that sometimes it works after ive rolled it and if i roll it again it stops working; i've checked all the electrical connections and they're all good, so now i think that its something in the gauge it self. But if it's just the speedo not working start at the sensor and work your way to the gauge checking all the connections. Hope this helps.
Look thru plenum at intake to airbox, make sure wires are plugged in...
Just had the same problem on an '08 600. I pulled the sensor out and cleaned all the grease off of it. That did not fix it. Replaced the sensor and it works again.
