09 RMK 700 clutching???
I have an 09 RMK 700 155 with a few mods done to it and with stock clutching and was wondering if there were any good clutch kits for my setup because I think it needs one pretty bad, just don't seem to go like it should. Also If anyone knows of any places I could get them sent out and set up?
It has a full slp exhast, pc3 with a map from jim, air horn, 19/42 gears) usually around 3000-5000 feet.
thanks
My 2010 700 is running a setup pretty close to what SLP has on their website. I beleive that it is a 65 mtx weight with 3 or 4 grams of rivets added, a black primary spring, a black/purple secondary spring, and a stock helix. If you haven't changed springs in a while, do so and some of your issue will go away. My primary is also balanced, which has made a difference. There a few places that can help you with that. Carl's Cycle in Boise, ID also has clutch kits. They use belly buster weights in theirs.
