sledhed88
Just bought this sled because buddy was tired of trying to fix it.
2009 M8, Twisted race kit
Sounds like what happened is he blew the Y pipe going up the trail. fixed that and then shortly after it wouldnt make rpm past engagment pretty well, would just fall on its face.it almost sounds like it is running on one cylinder but i have not confirmed that
Just quickly looking at it, the new kits are wired different then mine and im wondering what this blue cylinder is (electrical) by the right foot under the exhaust, and there is also a relay there. what are their purposes?
Buddy had it at the cat dealer a few times, sounds like theyve replaced,swapped
ECUs, same thing
servo motor for exhaust valves- same thing
flow tested injectors
pipe sensor is good
throttle cable is set proper
said they checked TPS
We are going to just take the stator out and send it in for good measures. But besides a bad ground or melted wire, what else could be going on
thanks
ECUs, same thing
pipe sensor is good
thanks
