At wot m1000 will live at 13.4 not suggested. 13.6 you get the end of a tow rope. If you see 13.6 youi cannot lift fast enough to save.
.....adding octane because of exhaust system mods is absolutely not necessary...only when head mods that increase compression or decrease squish, is octane increase necessary....addition of pipes, y-pipes etc, necessitate the addition of more fuel, not octane, hence the need for a fuel controller to increase fuel....the use of mid-grade gas is sufficient...i don't ride at low altitude, so i'm not familiar with what pump gas octane levels are, but they should be generally higher than at higher altitudes...where i ride (7-11 k), mid-grade is 87 octane and premium is 91....with similar mods as was reported, i use 87 with no problems.....the only problem i had with my 09 1000, is a bit of gurgle at 42-4400 rpm...with the bd box, i added just 1 number at 3000 rpm, both lo and mid.....at 5000 rpm, i took away 1 at lo and mid...tuning altiude was 8400 feet....i still had a slight gurgle at 4200 rpm, but throttle response was best with these numbers...i could get a slightly better throttle response by going to -3 at 5000 rpm, both lo and mid, but i was getting an occasional lean pop if i was at that rpm for more than a few seconds, so i richened it to just -1 for the best balance between throttle response and overall rideability without lean pops occuring....just discussing the low bog, as at higher rpms i added fuel all the way with high settings ranging from +5 to +8 at the higher rpm settings.....i clutch to 7350 on the road, with the clutching settleing back to about 7200 on the hills........i rode with these settings for four hours, and tried several minor variations, but always came back to these as being the best overall....plug readings were always safe, with the deposit/clean break on the plug electrode occuring at the bend of the "L", and max temps being 1225 degrees, with the egt sensor 2" downstream of the junction of the y-pipe/pipe....hope this helps..........
cat has come out with a new program they havnt given it to the dealers yet but it should help and 87 doesnt cuter 91 plus if you are stock arcticcats can run mid grade but and performance mods fuel quality must be higher
CAT has NOTNOT NOT NOT come out with a updated program
I wish you guys would learn this before you post to all users.
MD
