my 12 cat smokes 13 poos.just sayin.its a cat thing!!!Just got the 800 Dragon has Mountian tech kit. So GF was on my King Cat 04 900 162.we lined them up 3 times got smoked like a cheap cigar. Is this normal or right? What should i look at to get a bit more out of sled? I can turn circles around the King Cat
id say the dragon needs a clutch tuning.you shouldnt be getting left too far behind.belt?D8 has SLP pipe. Cat is stock. Cat set to run at 8-10,000 ft but we are at home at about 4200ft. Running straight in 8" if snow. I got the cat for about 50ft but then get killed. So its like 454 Vs. 350 fuel injection. CUBIC INCHES or CUBIC CENTIMETERS COUNT.
Are you running a Power commander? Prior to boosting my d8 I was running an slp pipe/can with a Pcv and Dynotech's 162 hp stoutner map. Made a huge difference
What is the weight difference between your GF and you. If it's a lot than that's your answer.
