Sorry, this info is with the polaris tool!It should be pushed toward the jackshaft bearing.
Is the offset measured with the clutch pushed tward the bulkhead or pulled toward you? This is in regards to secondary float.
I have heard/read a lot of conflicting thoughts..
Thanks
Ron , thanks for all the info you have provided in this forum. If you are willing, next time you call Carls talk to Chris and ask him if the PS47477 should be aligned with the driven held in or out. He told me to push in toward the bulkhead and set float with outer washers. I talked to him about 2 weeks ago and at that time he was pretty sure pushing in was correct. Maybe they can talk and come to a consensus. Thanks again, Ron.
I had a brand new SLP clutch alignment tool directly from SLP in I.F. last week... it was way off spec (bent?)
Definitely going to buy the SPX (Polaris tool)... Much thicker with all the angles milled into it... looks like a much higher quality tool.
I'm curious about the physical differences between the two models [47477 and the 46998] ... I'm assuming that the diff is the offset measurement as the primary end would be the same and the surfaces should both be parallel ... an $80 tool compared to the $40 SLP... IMO worth every penny.
As I read it ... and as the tool would work agrees with the service manual... the offset is the distance of the fixed sheave from the tool which would be set by the shims "between the driven clutch and the jackshaft bearing" [Like Jack said]
Float is different than Offset...
First set the offset (step 3 in the manual above) and then adjust the float away from that offset (step 4)...
Personally I let it float both ways as Ron said on both the 900's and the Small block IQ's .... I float it .10 on both sides of the offset measurement.
IMO... 1st find the zero mark for offset... 2nd set the outside float (washers under bolt) and 3rd subtract the same amount from the shims between the secondary and the jackshaft-bearing. You will have equal float.
I don't think, IMO, that the drivetrain is that sensitive to float as it is to correct clutch alignment.
Is any body using the Team alignment tool(s) seems to me that they should have it right if anybody does.
I was planning on buying the OEM Polaris one but I have a tss-04 and I have to do some work on a couple of 900's with the tss98 on them and don't want to drop $160 on alignment bars. This is also considering that the Tied is now coming to the market and I'm assuming that will most likely be yet another one.
The ones from Team are $50 ea and I would think they would do the job quite well but wondered what/if other's have found out differently.
