J
Jonce
Received my billet throttle body boot, not sure how it will work. I need to figure out how to fasten the throttle body to the billet boot so it doesn't blow off under boost. That's another day's project. I might tackle that on Saturday, we'll see.
Started the sled up since it was nice out. I will be doing a db sound test this weekend to see what it registers at 4k rpm's.
http://s92.photobucket.com/albums/l...n 800 Turbo/?action=view¤t=MVI_4113.mp4
Got my Skinz cover in the mail. At first I thought this was for a short track sled but Paul from Sled Solutions guaranteed me that it needs to stretch out. He wasn't kidding, I did fit after stretching the heck out of it. Sled Solutions has great customer service.
Installed my Mountain Addiction gas tanks. By far one of the easiest things to install, it took 5 minutes from start to finish.
WD40 the gas tank tracks.
Slide the rails into the gas tanks. Both rails should have the tapered end on the same side.
Put the screws in the tunnel tracks (similar to the seat post screws). Place the gas tanks on the tunnel and put the nuts into the rails. Use a 5mm allen wrench to tighten the nuts.
Installed
I then worked on the F-Bomb track mod. Cut the tips of the paddles off with a razor blade (use WD40 on the blade to help with friction). Then screw the tall lugs. I did 3 screws per outer paddle (i.e. 3 tall lugs). I did 2 screws per inner paddle (i.e. 2 tall lugs and 1 short lug). It took about 2 hours to complete. I used small trim screws 1.625" in length with a small head on it. I used a 1 lbs box and it was just enough with 2 left over screws.
Installed
