we ride 5000 to 8000 withe same sled and simmilar set up and we run 10-60 weights and they work well, pull 8150 to 8250
The weights do seem heavy for your elevation, but I bet you are like more than half the other dragons and are pig rich on top end. My 09 dragon would not pull rpm no matter how light of weights or how stiff of primary spring I ran. I had to put a pcv on it and trim the fuel on top.
I had the slp single with there map and had to take fuel back away from the midrange where they added a bunch and took more away on top. I ended up somewhere around -14% on top
Pm me your e-mail address and I will see if I can send it to you.
try a straight 38 degree helix. Works great for powder riding.
the belt should not be worn out at 500 miles you should be getting over 1000 miles out of the belt. I have had good luck switching to a 54-38-46 helix it works great
It never hurts to clean any part power valve. Pull the them off and take a look, the gaskets are cheap. If you do clean that passage out make sure you don't knock any crap into the motor.
So what would you say, piston up on the side you are cleaning or down. ie any little pieces of crap getting on the top of the piston or falling under it toward the crank? I know in a perfect situation no crap falling in would be best but I can't see how you could clean out those little holes with out pushing some chit into the motor, right?
