I have an 09 800 shift 155. This is my first year with it and I am still working on sorting some issues out. Ever since I got the sled It never wanted to rev much hugher then 7300-7400 up hills.
A few rides ago the wieghts were sticking causing the clutch to stick and kill the engine when it was trying to rev down.
Pulled the clutch and 2 out of 3 rollers were bassically flat and not moving and the other was shot, all the bushings were gone, pins had alot of wear, and to top it off the primary was snapped.
Since then it has all been replaced, primary now has an SLP black/pink spring, new rollers, bushings and pins.
First ride with the new clutch low rpms still exsisted. A friend pointed out the belt was far to loose on the secondary so the deflection was tightened up. This helped a significant amount. Highest rpm I found was 7950 now. I would like to get up into the 8000's preferabley around 8200 to get all the preformance I should be getting out of the sled.
Right now, the primary has the black/pink SLP spring and 62 ounce weights. Secondary is all stock as far as I know. I knoq lighter weights are the main thing for more rpm, but it already has the 62's and should do just fine with them from what ive been told.
I am basically just looking for answers on what I can do to get those rpms up to were I want them.
Thanks,
-Will
Thanks,
-Will
