SaskRMK
Alright closer to the end of the season i have noticed that some fresh oil was collecting under the engine and leaking out of the bellypan/exhaust hole. Upon further inspection the longer my sled sat unused the more oil would drain from the oil feed line from the reservoir but only underneath the check valve from the pump. Because of viability and residue on most all portion of the pump it was almost impossible to determine what is actually leaking so i started with replacing the feed line but still had a 2" air bubble appear in the feed line right under the check valve after the first night the sled was ridden after the line was fixed. I bled all of the air out of the line before reassembly. What could be causing this issue? is there a seal around the pump where it mounts to the block? O rings on the pumps shaft?
Thanks for your time
