L
leiterch
I see this issue being discussed, but mine seems different, so I wanted to get some input.
I have an 09 600 CFI and I am getting a blinking display. So here are the symptoms:
Everything is fine at Idle
Sled starts with 1 pull (maybe 2 when cold) every time
Sled runs great no performance issues
Highbeam Indicator, Reverse & brake light (when pulled) stay one when display starts blinking and/or goes out
No Dimming of headlight when display goes out
Blinking starts when I rev the engine and then it goes out and then resets just like you started the sled up fresh.
I have wiggles wires around and don't seem to have anything grounding out when idle. It only happens when you throttle up past 2 - 3k RPM.
At first I suspected water in the connection between the hood harness and body harness, but blew it out and sprayed down with WD40. Still have the problem.
I am hoping that I am not on the VR train. I haven't seen too many 600 CFI sleds with this issue. Not sure if it was an 800 issue only. I don't want to fry an ECM if possible.
Is there anyway to check the VR?
Does anyone have a wire diagram so I can measure the VR?
Thanks.
Thanks.
