Hi
My 08 Summit X runs great for about 3 seconds at WOT. After that it appears to start run rich and bog down. It will hit about 8000 RPM and then just start sputtering and dropping RPMs quickly. You can let off the gas and repeat the same behavior over and over. It will do the same thing on a stand with no load. What is interesting is that it seems to run fine when you remove the air box. We have checked all the sensors and airway and everything looks good. I also had the dealer hook their computer up and it is not throwing any codes.
Thoughts?
Thoughts?
