08 m8 pgt what is peak hp rpm?
B
burried
New member
08 m8 pgt with speedwerx y and pipe
i got 80 grams weights
my rpm is at around 7800
what should it be?
so 7800 rpm too low? lighter weights?>
or more boost.
That sled should be between 7900 and 8100.
I ran 79 grams in my 07 up to 12 lbs, 7900-8200 was what I had. I put those same weights in my 2010 and it was running 8600 at 12-13 lbs. I'm now running 83's in my 2010 up to 13 lbs.
7900 at the lowest and 8200 at the most. What elevation are you guys running. I'm running 6.5lbs at 9000+ ft with 72g pulling 8-8100.
I am running boondocker pgt on my m8 '09
elevation about 5000ft
80g
9 psi
max rpm 8460
I ordered 83g weight and i hope that my max rpm will go down after replacement.
