08 M1000 electric reverse kit
Seconds thoughts yet about switching to doo. Your sled now sports a 174, power commander, ve tunnel and is all black. Electronic reverse works fine.
no second thoughts yet buddy! i'm garage riding the chit out of my new sled though. BRAPPPP!!! :D
send pics of the modded beast!
How are you gona save 12lbs without putting a 09 gearbox? And thats gona be pretty expensive...
What is the big gain with this compare to stock 08 reverse?
The 08 shift mecanism weights only about 2-3lbs...
Do any know the diffrent weights of the boxes?
05-06, 07-08, 09-10 and bdx boxes?
I can messure the a 07 box if some of you can messure the rest??
http://bd-xtreme.com/bdxdiamondlitedrive-1-1-1-1-1-1-1-1.aspx
This will save 9lbs on a 07 and 2 lbs/09...
This is right from the BDX website:
"New for 07' - UP M's and Crossfire is our Diamond Lite Drive system that takes off a true 11 lbs (07'-08') 4lbs (09') of unwanted weight."
The BDX lite gear box looks very simillar to the 05/06 M7 gear box. It's a LOT smaller than the huge mech reverse gear box. your not only saving weight by removing the shift mechanism, but all the reverse pieces INSIDE the gear box (many of which are rotating parts), plus you have to run the billet driveshaft from BDX as well, which saves even more weight.
It's good mod that's not that pricey if you can sell your stock gear box for $300 to $400.
I see no reason to do this mod if you have an 09.
should I
looking into buying a 08 m8 new in box, What will
I need to do to add Electirc reverse? I can save over $1500.oo by buying a 08
looking into buying a 08 m8 new in box, what will
i need to do to add electirc reverse? I can save over $1500.oo by buying a 08
but buy the time you spent the money upgrading it and putting reverse on it youd have close to 1500 in to it with 20 less horsepower
What are you guys doing if you can’t afford the DD lite? Are you just stripping the servo adding a helix and letting the dd run backwards?
Ye..but you need the bdx shaft to save 11lbs and 4lbs...
And that shaft saves you 2 lbs... that means 9 ad 2 lbs to save.....
I bearly se any reason for this el.revers mods at all.
I did put on a lightweight hood and saved 20lbs.
Again what is the big gain with this el.revers kit??
You dont even get 1 more hp at the track.
Wait until your stock DD grenades, then you might understand. The mechanical reverse is junk and will eventually go out. Aside from being lighter and stronger it also gives a guy a good excuse to regear.
Can you push the reverse button when going down hill to help slow yourself self down? Just wondering like going down on the monster hills u hit rev and spin track to slow yourself down.That s why ive kept my drive stock just wondering.
The revers is not the problem on the 07-08...And i have changed the bearing that is the problem 3 times, and now with a upgradet bearing that have lasted..http://www.snowest.com/forum/showthread.php?t=151644
this bearing problem is on on 07-08 and even 09...
You can do that on a 07-08 also, you have to lock up the track anyway to get it into the reverse...But I dont like this kind of manuver..it feels wrong..lol..
Sorry my fault I wasnt clear enough ,I own a 2008 m1000 just wondered with the newer sleds with the el reverse in the motor if you can still do that down the hill ?
I personally don't use reverse for down hill descents but the 09 and up electronic reverse will work going down hill but they have a rev limiter and I don't believe the 08 and under have one.
If you hit rev going down hill on a 09 it rev limits at 4000rpm, and burns the belt. the secondary wont engage on the 09 in rev so if it rapped any higher it would over engage the primary and not the secondary causing it to stretch or blow the belt. and if you do the E reverse on the 08 the oil pump doesn't work in reverse and if you really got on it you could risk blowing the motor. In other words its a bad idea. I did it once because I had no other way down, it did not work for beens and wound up in a tree.
Have reverse wiring kit in stock ready to ship for 15$ with instructions. PM with requests and I will provide payment info.
jeff is still selling these and if you have a 08 m8 i will work for them also for the 07 u need the 08 ecu to make it work
Million dollar question... Can this work on an 05 M7.... ya I know it's really pushing it but what the hell it can't hurt to ask.
