Looking for info so I can go to my dealer with as much info as possible. Approx. 300 miles since the update was installed.
Last weekend, I noticed a couple times where the gauge went blank. Also noticed a few times where it was blinking low voltage indicator as it idled.
This weekend, got up to the bowls, took a couple good runs, went to make another, and the sled cut out, but came back when I let off throttle. Turned out before I got too committed to the climb luckily. Gauge was intermittent, I killed the engine, restarted it, seemed to run fine, start riding it, cuts out again, gauge not working any more no matter what I try. Idles fine. Next time I try to ride it dies, and I smell a funny smoke, finally figured it smells like electronics smoking. It started a couple more times but died again as if you turned it off.
Ended up towing it back to the truck and riding my buddy's spare sled.
Tonight I pulled the exhaust valves and plugs and saw some things I am not sure what to think of. I am thinking of asking the dealer to pull the top end. I think I will run a compression test on it too although compression "feels" fine.
Both piston tops are shiny clean looking in the plug hole but you can't see a lot from there.
Looking in the exhaust valve ports, the mag side piston looks to have a little pitting on top, and the side of the piston does not look like a piston with 300 miles on it. Broke it in with Polaris Blue as recommended by Polaris. Just this trip I put gold ves oil back in it.
PTO piston has a wierd whitish blemish on the mag side of the piston above the top ring, looks almost like oxidation if I didn't know better. Rings almost look like there is some metal dust in there with the ring, does not look clean, and again the piston does not look like a 300 miler.
I tried to take a couple pics which I will post but it is hard to see, although the white blemish on the mag side of the pto piston shows fairly well (looks like a reflection though). It appears to have a little scuffing on the skirt too but not a lot.
Any ideas? Should I ask the dealer to pull it down and call me when they got it apart so we can look it over together?
Sorry for the quality of the pics, hard to get a good closeup of what I am looking at.
![P4184195 (Medium).JPG P4184195 (Medium).JPG](https://www.snowest.com/forum/data/attachments/90/90053-41c0e21ad24175a21c7dc153cb2eadde.jpg?hash=QcDiGtJBda)
![P4184191 (Medium).JPG P4184191 (Medium).JPG](https://www.snowest.com/forum/data/attachments/90/90039-8893794c02dff682dbb298f66b934d64.jpg?hash=iJN5TALf9o)
![P4184192 (Medium).JPG P4184192 (Medium).JPG](https://www.snowest.com/forum/data/attachments/90/90044-306d2e6ab15eca2c334f4844f9e5bd56.jpg?hash=MG0uarFeyi)
![P4184193 (Medium).JPG P4184193 (Medium).JPG](https://www.snowest.com/forum/data/attachments/90/90047-673bc3b8236ebd3654e6839bb9ee8c2d.jpg?hash=ZzvDuCNuvT)
![P4184194 (Medium).JPG P4184194 (Medium).JPG](https://www.snowest.com/forum/data/attachments/90/90051-dda8b48a40a257995b2322993242d88f.jpg?hash=3ai0ikCiV5)
