08 D8 spark cutting out
6
660canuck
New member
After installing the fix kit on my friends D8 I cant get it to start. It's getting fuel and has compression but the spark is cutting out. Every time you turn it over it sparks for a brief second and the nothing. It seems like the spark is being cut for some reason. I am not very familiar with Polaris so I am looking for a little help on this one. Prior to the new top end going in it was still running but the sled had gone into limp mode.
Check throttle cable adjustment. There is a safety switch within the throttle block that may be your problem. Make sure there is a small amount of freeplay in the throttle cable when you are at idle.
