MY P.O.S. had a crank bearing go out 2 weeks ago. They denied my warranty because I had an "unapproved intake modification". I have owned that thing since new in 12/07. I got sick & tired of pulling ice, snow, dirt & pine needles out of the top of my box, or having clogged air intakes due to deep powder. I installed a K & N style fiter on top of my airbox. I took out the airhorn under the hood & had the filter sticking up into the air intake area by the headlights. My airbox was stock on the inside, with the shelf & 3 air horns intack. I had a stock pipe. So my warranty is void because I fed it fresh, clean, filtered air! It has been towed in 4 times in 1500 miles: 1) ecu fried. 2& 3 beacuse sized twice last winter, BOTH TIMES it needed new pistons. 4th tow was the rod bearing. GEE YOU DON"T THINK SIEZING THE MOTOR TWICE AT 7000-8000 RPM DAMAGED THE CRANK BEARINGS DO YOU? I had the great "twin ring" rebuild in 12/2009 and thats when I put on the air filter. The thing actually ran good after that. Every mechanic I have talked to says there is NO WAY that air filter hurt that motor. The pistons & rings look perfect right now. ANYWAY I AM NOT FIXING IT. I am buying a used M8 to ride, will leave the polaris a pile of parts so I have proof for the Lawsuit I am starting. They have F'd enough of us. Anyone with a similar story, PM me... Bill
WOW! WTF Polaris! Is it me or is the current 800 debacle making the Fusion 900 look like a success story. I think there's some serious issues over there in Minnesota, they're coming up with alot of excuses to avoid responsibility.
