08 700rmk rpm ?
D
Dosch99
New member
what kinda of rpms should a stock 087 700 rmk 155 with 10 -66 weights run at. elevation is right around 1500 ft, get up to about 8200 on hard pack was riding in 8inchs of snow seems like the rpms fall off to around 7800 7900. Thanks
8250 is what I look for in my 700, that seems to be the sweet spot for me. I run 10-64's and an almond spring running from 1000'-4000'.
what could cause lose of rpms in the deeper snow, clutchs were cleaned new spring in primary, the only think i havent done is put a different belt on yet was gonna try that next
Is your current clutch set up original? You may just need to freshen them up with new springs (both primary & secondary), weights, delrin washers, and re-adjust alignment, deflection, etc as needed. A new belt can also make a difference even if it doesn't look worn. I'm not a clutching guru, I depend on others on here and my local dealer who has always treated me right.
X2^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ++
+ Dirty exhaust valves
+ Fuel filter
