B
What are some cheaper mods to do on a 08 dragon 700? I was wondering what some of the guys on here have been doing for a little extra power for these things. Anything welcome. Thanks
- Back in '08, Monster decals were rumoured to add 10 hp.....
One of the guys that rides with us has a 08 with the 163 the shop here told him to just put on the can. Pipe does not make that big of a difference. After he put it on there was a noticable diff. Track would be a good upgrade also or better yet a turbo LOL depends on how much you want to spend. Have fun good luck they are good machines. Jim
PIPES AND DYNO TESTS
DYNOTECH JIM tested (xc8 on H.C.S.) 2008 DRAGON 700 on New Year's day, tried the SLP pipe, minimal gain ONCE THE FUEL CONTROLLER WAS OPTIMIZED FOR EACH PIPE SET-UP, they re-installed the stock pipe and the aftermarket pipe was up for sale.
Run your chain a little looser, get it to where it touches the back of the chain case by pushing on it.
So what is the PC III? what does it do? I think the guy who had mine before me must of aligned the clutches or something. because I can pull my dad on the hills and my uncle on his 800 rev even in a drag race, and he has a 151 compared to my 163. Either that or Polaris just rocks, i think both.
brad,
i'll get ya hooked up with all the vents you need, as well as the can. we can do some custom clutching this winter for ya and make sure you can embarass dad even more
that is a good way to break chains, or strip gears leaving yourself high and dry in the mountains. proper chain tension is generally speaking about finger tight, backed off half a turn from that point. have seen multilple sleds get towed back and have been on a few rescue missions myself from guys running their chains too loose. the rest of your reccomendations sound good though
I have a 2007 D-7, 3700 trouble free miles, my bud has the identical sled, 2500 trouble-free miles
BEST BANG FOR THE BUCK MODS
PC III from Jim @ DYNOTECH, $365.00 w/MAPPING INCLUDED (www.dynotechresearch.com) (585) 993-2777 I'm @ 5-10% LEANER on top, RICHER in the mid-range, that dreaded 5000 r.p.m. flat spot is GONE. The 2008 models were supposedly 5% RICHER than the 2007's so you may be able to go leaner, but that's your call. After the install of the PC III, it's the first time my plugs had any color on 'em other than black.
SLP push arm (part # 23-63) , installs on the MAG side, (2) holes to drill, 20 minute installation time
ALMOST FREE MODS
I checked the engine belt/alignment and center to center, (c/c was fine) offset alignment (engine crooked) mine and my bud's were WAY off, removed the engine and slotted the MAG side engine bracket an unbelieveable 1/4" to 3/8" to get it straight. And yes the tools I used are good and straight, I actually triple checked them plus used Slp and a GENUINE GOLD PLATED POLARIS tools, same end result. Other guys on H.C.S. reported similar problems.
Check your belt to primary sheave side clearance with a new belt, set it at .010" to .015" (mine was .070" from the factory)
Lightly sand (w/180 grit) your clutches perpendicular to the way the belt rides and wipe down with lacquer thinner.
Wash/scrub your new belt w/soap and water and let dry, sounds weird but it removes the mold release compound that would otherwise get smeared all over your brand new clutches.
Oil pump setting, mine was 37:1 ratio from the factory, I adjusted the 10mm nuts down by the oil pump (Yeah a P.I.T.A. ) 1 1/4 to 1 1/2 turns and it's @ 57:1 for the last 1200 miles. Picture of oil pump posted below, small horizontal mark stamped on arm (3:00 positon) should line up with short horizontal mark on the red dot protruding out from the case AS A STARTING POINT.
DEBATEABLE
I installed the SLP big horn air kit + (4) flo-rites, didn't notice any gain.
WASTE OF $$$$$$ AND YOUR TIME
I did the V-force reeds, maybe slightly more responsive on it's best day, NOT worth the $$$$$$$ and installation time.
Hope this helps
